Fisher Pierce Bearcat 55 parts
  • Fisher Pierce Bearcat 55 parts
    Parts available. Please call Jon at 919 604-3697. Leave a message if I can't answer and I'll call back.
    Distributor IGW-4406A complete, w spare coil: $140
    Tillotson MD120 Carb kits (2): $25 each
    Tillotson MD120 Carb accelerator pump kits (2): $15 each
    Prop nut: $20
    Rotor, condenser, points: $20 for all
    Rectifier: $10
    Shear pins (4): $20
    Michigan Wheel propeller (spare, never used): I need to determine price, make an offer
    Above items are price + cheapest available shipping
    Other items available for shipping cost, or for free with purchase from above:
    Inerds from distributor IGW-4406A, removed for installation of electronic ignition
    Fuel line connector
    coil bracket
    lift bracket
    Coil resistance wire
    Original starter solenoid, suspect bad
    Original fuel pump, suspect bad
    rubber funnel from crank case into oil sump
    O-ring, exhaust manifold to leg
    O-ring (2), block to leg
    _____________________________________
    1970 Boston Whaler Sakonnet w/ Bearcat 55
    1960 Chris Craft 18' Continental w/ 283 ci V8
    The only thing left is the Prestolite distributor IGW-4406A, complete, with a spare coil, $140
      ALL PARTS SOLD -- Ok, I've got $135 into this between finding a distributor base and the parts to refurbish/complete it. I guess it isn't worth that. How about $75. Jon
