1968 model a little different? or case of missing bearings
  • 1968 model a little different? or case of missing bearings
    Looking at my condensed 1967 Homelite diagrams exploded view of pinion shaft bearing above gear on bottom end shows two bearing a tapered and above that another bearing this a ball bearing type. I only have the tapered is this correct? for the later version? as my driveshaft has threads on that end which is different from my diagram as it shows drive shaft splinned on both ends. also another set of needle bearing cage above the ball bearing and below the cage under the waterpump. My model# is 460A2F can anybody shed light on this. Regards, Paul
    [QUOTE=frogpond;26751 I only have the tapered is this correct? for the later version? as my driveshaft has threads on that end which is different from my diagram as it shows drive shaft splinned on both ends. also another set of needle bearing cage above the ball bearing and below the cage under the waterpump. My model# is 460A2F can anybody shed light on this. Regards, Paul[/QUOTE]
    What you have is correct. I put together this webpage a while back, it shows the differences between them.
    http://home.comcast.net/~273cl72/sit...552fdf6d9647e0
