Results 1 to 7 of 7
Thread: Uncommon Homelite/Bearcat 55 manual
    My dad had a poor and degrading thermopaper copy of a 55 manual, made from a long lost neighbor's manual. I have searched for a copy of the manual for years with no luck. This summer I inquired with a technician at a Michigan marina that used to sell Bearcat/Whaler. He went to a back room and pulled out his old dusty, greasy paper manuals and there it was, so I believe it was a manual available to technicians rather than the general public. He graciously had an assistant scan and email each page to me. Unfortunately they were large image files, and a couple pages were missing. Iíve converted each file to PDF and combined them, inserting scans of my poor quality version for the missing pages. I find this 77 page manual more helpful than the commonly available one and want to make it available to other Bearcat fans, and this seems to be the most active Bearcat forum. The contents page is posted here. The full file (126 Mb) is hosted on a work server, but only for one week before it is automatically deleted. It can be downloaded at the address below. It takes a couple minutes to download so be patient. Do others have this manual?
    http://www.med.unc.edu/uploads/xwmap.bearcatman.pdf
    Jon
    _____________________________________
    1970 Boston Whaler Sakonnet w/ Bearcat 55
    1960 Chris Craft 18' Continental w/ 283 ci V8
    2,907
    Quote Originally Posted by jhomeist View Post
    Jon
    Hi Jon.
    A Big Thank you is in order and I hope to share this with other Bearcat nuts like myself.
    I did download it and No I don't have some of the items in it so this is a Big Plus.
    Some of these are getting harder and harder to come by so, Great Score !!!
    Thanks for sharing!
    Member frogpond's Avatar
    Aug 2009
    1958 Glasspar Mariner Sport Model
    Port Orchard
    91
    Can somebody put this file up again as the link is dead. Thanks, Paul
  5. #5
    I posted the file again on a temporary file share site at work. It will get purged in a week. Until then, it can be downloaded at this link:
    http://www.med.unc.edu/uploads/jrkdd.bearcatman.pdf
  6. #6
    Aug 2009
    Port Orchard
    91
    Thank you Jon really appreciate your effort on re-posting manual for us that missed it the first time. I think I hosed up my throttle cable I wasn't able to have a low enough rpm to shift ,so I shorten the cable cutting off about 2" now I don't have enough throttle The cable cover was all chipped up cracking so it's not a great loss. I need to understand the the shift lever on control unit "Shiftmaster" hopefully this manual will shed light on this unit. from what I can tell now having boat on the water for first time the small lever is tied into throttle when in big lever is in neutral position. So I guess I have a question when running what position should the little lever be in ? I have it in shift but something isn't right.
  7. #7
    Supporting Member Supporting Member Super Sportster's Avatar
    May 2009
    Sylvan 16ft Super Sportster
    Gresham
    307
    Did you mean "SafetyMate" for the control? On the SafetyMate control big lever in the neutral position small lever pulled up, choke on, start the engine and adjust speed with the small lever until warmed up. Push in into the down position after warming up and you are done with it as it will now be in the idle mode and all controlling is now done with the big lever.
    1989 16ft Sylvan
    '58 Johnson 5.5hp
    '64 Johnson 18hp
    '66 Homelite
    '70 Bearcat 55 (2)
