Homelite face lift
  • Homelite face lift
    I moved boats around the place, and thought it might be good to give the Homelite some attention. First I gave it a good washdown with Prepsol, a good wax and grease remover. Next I masked off the emblems and the second color(blue). I wanted to remove the emblems, but somewhere along the line they have been glued on. With some careful masking and a little razor-blade work I got pretty close.1/4 inch fineline tape helps as well.
    I sanded with 220 grit on my random orbit sander. Around the emblems I use red scotch-brite to knock off the shine. Then comes three coats of primer,I used Naps's two part as I had some left over from another project.I did some minor fill work with a light filler but most of the imperfections came out in the sanding and primer.
    After sitting over night to dry, sanded with 320 grit and scotch-brite again,Blow off with compressed air and wash down with Spray away glass cleaner to clean off the finger prints and stuff but leaves no residue.
    And last I sprayed three coats of Napa Acrylic Enamel. It was pretty cold and has taken a couple of days to dry but looks ok. Now the blue looks a litte worn. I guess its good to have somthing to do! - Ross
    Ross Henson
    The Homelite Looks GREAT Ross! Looks like it just came off the showroom floor. Nice job. These fun winter projects like this make winter go a little faster don't they? Did the top come with your Bell Boy?
    Kent & Diane
    '58 Westerner
      Looks good Ross, nice work. I picked up my Homelite from Bill yesterday. I'll being doing the same to mine this weekend. The emblems are shot on mine, so I'll be removing most of them, that should save a little time. Bill is working on getting emblems made up, so I'll just put new ones on sometime down the road.
      Got new cables on the way also. Hopefully I can do a test run at Lake Stevens in a few weeks. Can't wait to get this baby out on the water. Should be fun.
      I'll post some before and after pictures when I'm done. The finish on the hood is shot. So even if I do it blind folded it will look better. Hope it looks as good as yours. Have a good one.
        Very nicely done Ross, can hardly wait to get ours.
          Bearcat Engines
          Great Ross.....
          Now I am going to have to do something with mine to keep up with you guys.
          Looks good
            Thanks these small projects are fun. Westerner, the top is a new project as well. I'm doing a last try on before finishing up the fairing and paint.
            Steve and Melanie you will like these outboards! When my wife and I went up to Bill R's to pick up mine it happened to be on mothers day,so now she tells people that is what I got her for mothers day... an outboard.
            Yes I am lucky - Ross
            Ross Henson
              I'm jealous, mine is still in pieces all over the shop in various stages of prep and primer. Hopefully it will be together in a month or two.
                That looks great. Bill is supposed to have one in his shop with my name on it. Thanks for the info. You just inspired me !!
                  Bearcat engines
                  The Bearcat engines are not hot rods but they are really a head turner.
                  Most people have never heard of them.
                  All I have to say about them is sip sip sip
                  I think Melanie has one in the works too. I know she has been waiting for awhile now too.
                    Finally got the Homelite spruced up. Thanks for the tips guys (Bellboybob, Bill and Ross). Turned out okay as long as you use the 10 foot rule. Like we used to say in the Army, close enough for government work.
                    Looks a little plain without the decals, working on getting new ones. The first mate suggested it be painted gray instead of blue, so it's gray. (nuff said about that).
                    Just have a couple minor connections to make. Going to take it for test spin next weekend. Can't wait. Sure will be nice to have 4 stroke power. Attached are some before and after shots.
                      Steve that looks good to me! I think you are gonna like it. Billr was talking about putting some insulation in the hood but its pretty quiet as is. Where are you going to launch? Enjoy! - Ross
                      Ross Henson
                        That sure cleaned her up for sure.
                        I am still looking to match or get close to the stock blue.
                        Seems Krylon has come out with many more colors that I will check out.
                        Ross, what did you come up with for your Blue and White?
                        Kind of like the gray but want to stay stock looking.
                        Mine will run right now too, thank to Bill.
                        Overlooked the simple stuff, geeze....
                          Steve,
                          It really looks sharp! Can't wait to see it! It really is amazing what some new paint can do.
                            I spent hours back a year or so ago on my hood masking and painting with spray cans, everything looked good until the final piece of tape peeled off taking some paint with it. I was very dissapointed but I will try to spot paint that area.
                              I have been spending the last week or so cleaning up the old Bearcat. I painted the leg and a little detail work on the hood plus cleaning up the controls.
