Pictures
  • #31
    Originally posted by Steve_Kiesel View Post
    A test to see how my profile picture displays.
    Figures.
    That sounds like you're not happy. If I misread your reply, my apologies.
    You uploaded a profile picture, and I see it on your profile page. Did you want an avatar? That's the picture that shows on each post. It's a separate setting, although you can upload the same image if you like. It's on your profile settings page, just below profile picture.
    • #32
      Not unhappy Ed, just confused as usual.
      Under "Edit Avatar" it's set to do not use avatar's. When I click on it, it does not allow me to change it. No message returned when I click on it.
      I also have "Show Avatar's" checked under General Settings.
      Not sure what else to try. That's why I was using profile picture, figured Vbulletin was different.
      Any direction will be appreciated. Thanks
      • #33
        I am looking for that feature to check the settings. Things have changed to a little more advanced for me but looking.
        I was able to do mine so its got to be in what they call permissions I think. Off to it..
        • #34
          Try this...
          This is how I uploaded my avatar, hopefully that works for you...let us know if not.
          • #35
            Well I was starting to think I would never be able to post again but maybe I will learn the new layout. I still do not see an Icon for photos, where can I look for it?
            • #36
              Craig, see page two of this thread...it should help you out.
              • #37
                I don't think I can post yet. test test
                • #38
                  Thanks Kelly. This time when I went in, the "Custom Avatar" was displayed so I could click on it. It let me upload my Avatar. (Mill Creek guys, that's the little picture that displays in the upper right hand corner when you post).
                  • #39
                    I'm glad it helped Steve! Nice job!
                    Craig, I'll look into why you can't upload a pic...
                    • #40
                      testing this out using the file attachment.
                      • #41
                        I think part of the problem is when I first select the picture icon in the reply section I initially don't get an option to upload from anywhere. see this picture:
                        but if you let it sit for a couple of moments then you get the option as seen here:
                        Additionally, one thing that could help some folks also is to make the "upload file(s)" a "box" you can select. Without the "box" around those words, it doesn't look like something you can select.
                        • #42
                          Thanks for the feedback!
                          Ed, can you take a peek at this to see if you can alter the image option that he's referring to?
                          • #43
                            This a test. Only a test.
                            You may return to your regular postings!
                            It worked.
                            1958 Dorsett Farallon
                            1959 Bellboy Ballerina
                            • #44
                              see what happens.
                              • #45
                                Ok I still have no idea where the icon for photos is?
