WHAT HAPPENED TO ALL OF THE THREADS? They're not gone, I'll show you...
This is a sticky topic.
  • WHAT HAPPENED TO ALL OF THE THREADS? They're not gone, I'll show you...
    If you're like me, when you first logged on to the new forum you may have thought "what happened to all of the threads?" They are still there, you just have the power to see as many or as little as you want. Check it out...
    1958 Skagit 20 Express Hardtop
    -PNW Craftsmanship
    Don't forget about the FAQ page if you need help with the forum:
    http://www.classicboatclub.com/faq.php
    This method does not work on the mobile playform... Which, by the way, is currently garbage. With mobile access I can't even change my password. I know you administrators are swamped with this so I do not expect a solution anytime soon, just want to make sure you all are aware of the situation.
      ugh...thanks Brian.
      -PNW Craftsmanship
        Kelly, the mobile version is absolutely unbarable but, at least on my iPhone, there is a button at the bottom to switch to full site mode. Then everything shows up correctly and I can actually see pictures... It's quite a bit slower but at least navigable.
        Good luck!!!
          Thanks for the update and thanks for your patience. We'll get it dialed in...
          -PNW Craftsmanship
            Brian, at the bottom of the page should be where you can change screens and one for Mobil.
            There is only one selection for Mobil. Is that the one you are using?
            Let me know as if that is not working for you, we need to make it work.
              UPDATE: If you want to see all of the threads all of the time without having to change the setting each time, go to the settings page (settings link is at the top of the page) and choose "show all threads"...don't forget to save your settings at the bottom of the page.
              -PNW Craftsmanship
