I have a 1961 Seafair Phaeton but the transom probably is the same as the other Sea Fair line. The boat looks like it was always stored indoors. No rot can be found anywhere on the transom. The original motor is a 1960s Mercury 700. I obtained a 1978 Mercury 900 over the weekend and when we placed it on the transom and bolted it on there was a noticeable wobble in the transom if the motor was pushed somewhat. There are no noticeable cracks anywhere in the transom fiberglass or splashwell and as noted no rot. The Mercury 900 does not weigh much more than the 700. If there was a wobble with the 700 it was not noticed. I have not run either engine on the boat so we don't yet know what happens on the water.
Has anyone had a similar experience with any of the Glasspar Seafairs? If so, what transom modifications did you make to reduce the wobble? Did it work?
If you simply lived with the wobble did anything get worse?
Bruce your Seafair looks original, could you get me the measurement of the rear tow eyes, from side and bottom of closest edge to on center of eye measured from outside. Mine have been moved and both are different
want it right when redoing the transom... Thanks Bill
Bruce, thanks for remembering at all
