I have a steering cable issue. The right side became disengaged from the spring that is in back by the engine, creating too much slack on the left side. This caused the loose cable on the left to get tangled up around the pulley that is directly below the steering / under the wheel.
I unhooked the cable from both springs in back which gave me enough slack to crawl under the steerling wheel and uncoil the tangled cable.
However, although the cable is still threaded through the pulley under the steering wheel, I don't know how to rewrap it and reestablish the tension / tightness that should be there.
BTW, this pulley and cable were recently replaced so they are in good shape, just need to be rewound.
Hope that makes sense. Is this an easy fix I can do myself? (I'm pretty good with mechanical things if I have instruction). Or, is this a complex issue that I should have professionally fixed?
Thanks for your help.
