I need a few things to complete the Saratogan restoration.
1) any info on working with Formica would be appreciated.
2) Any info on working with Plexiglas, especially cutting would be appreciated.
The stuff I have is 1/4 inch thick.
3) I need some mild steel (cold rolled). About a foot of 4 inch angle iron, 1/4" wall thickness. Ten inches would do.
4) 1/2" steel plate about 11 inches wide X 36 inches long. This to modify the boat cradle so I can get the boat level.
Any info would be appreciated.
Thanks in advance.
McSkagit
Thanks in advance.
McSkagit
And his tips on cutting are right on although I use a plain old utility knife to score and snap. I have carbon tip style one but find the utility knife works just fine and I use Irwin blades available at most lumber/home improvement stores of your choice. Much stronger than generic brands, change blade often.The one caution I have is that the edge of the Formica is darn near razor sharp in itself. For this application go with the really smelly contact cement rather than the latex type and work in a _well_ ventilated area and if you have a resporator I highly recommend using it. The price quote is about right. Depending on just how much area, color choices,same color for both areas(?) you should call around to see if any shops have some remnants.
