70s 70hp wiring digram
  • 70s 70hp wiring digram
    I'm working on a 70s 70hp Looper and need a wiring digram for the motor. Got power to everything but no spark. I has a power pack and don't know were it gets its power from.
    Mike
    There is a red wire on the power pack harness,it's the hot one. If no spark is your issue, power and/or coils need to be replaced. If it's the origional power pack, replace it. that's most likely your problem. 30 rears is a long time...
    ChuckB
      Check kill + grounds
      I`ve found the killswitch and grounds can stop spark too.
      Undo the main red wire plug,then jump the solenoid with a screwdriver to check for spark.If spark ,then harness ,keyswitch is trouble.No spark and proceed to pack and then coils.
      Pulling the Black /Yellow wire from the plug where the 3 coil wires enter the Black rubber Boot will test the kill-circut from the power pack.
      Some new power packs make you fish the new leads into those rubber boots so take good notes......Blu/Orange will be upper cyl # 1 ,Plain orange # 2 and Green/Orange bottom #3.Firing order is done with order they mt in the plug.
      Some packs offer RPM limiting which is always wanted except for when running Jet Pumps.
      I always go for the factory parts over CDI aftermarket stuff but price can dictate too.
      Goodluck,
      Tim M
        I had CDI units one my old snowmobiles and never had one go bad. So I will start checking one thing at a time and see were that gets me.
        Thanks
        Mike
