Back from vacation and back to work!
Before heading out for vacation I managed to get the paint off of the stbd side and mark up the hull. I also got about half of the fill in place. This last weekend I sanded the repairs down and am overall pleased with the results. There are a few areas that need touch up, but the work looks good. I used a flexible longboard sander for this work. It really hugs the contour of the hull nicely!
The one thing I am unsure of is the feel of the areas I repaired. I can't get the 3M beads to sand down as smoothly as I would like. I am hoping that the epoxy primer I am going to use will fill this roughness and allow it to be sanded smooth prior to paint. I'll have to do a test spot before priming the hull. If it works, I'll do the whole thing. If not, I'll have to sand down the repairs a bit more and then put something else on top to smooth it out.
The deck has a good amount of yellow in some hard to reach spaces. So, I decided to use some paint remover. Bad mistake. As I worked my way around the boat, I dropped a few bits on the plexi on the port side slider window - and didn't notice... 15 minutes later and I now have 4 nice gouges in the plastic. On the surface it would seem easy to repalce the window, and maybe some day I will, but it will require the removal of the window frame to get it out. Problem with that is that the screws, aluminum, are fused to the frame, also aluminum. I tried getting one losened up but it just wanted to strip the head. So it will probably require me to break the heads, tap them out and replace. Not something I am excited to do . Anyone have any suggestions on removing them? If there is a magic liquid I can put on them I'll do it. I'd love to have the frames out of the boat for painting as well as the ability to clean up the sliders and/or replace as needed.
I'll snap some pictures of the sanded hull and repaired areas this week and post up.
Here are some shots of the underside with the first coat of primer on.
The plan is to have the deck paint on this spring.
