Tail Heavy?
Mark,
I`m really worried about wt.balance with the similar Bellboy hull my buddy owns....
I made sure to add flotation to keep it hopefully level with the new Swimstep /Motor bracket I`m almost done with.Not sure I added enough....
Seeing yours already at a nice angle (but before the 2nd motor is hung) leads me to suggest maybe a test float with a full trash can or two filled with enough water to simulate the actual load.
You can even overload it to see what a 4 person crew and fuel would cause.
With water you can siphon it out or bail with 5 gallon buckets to quickly empty the weight,then do another test run to get a good baseline for seeing the difference between the two.
Or get some bodies and tell everybody no dancing.
Save that for the happy owner!
TM
Mark,
TM
Now all I have to do is paint and install the twin outboards, controls and steering wheel. Just a few more months away I hope!
