Needle Bearing removal
  • frogpond
    started a topic Needle Bearing removal
    Hi does anybody out there have experience with the removal of needle bearing in the upper lower unit these are located directly below water pump housing. I'm working on a 1968 Fisher Pierce "A" block Thanks, Paul
  • frogpond
    replied
    Further investigation: seal replacement Timken 1049 also found the right size O.D. to use as seal driver lying around the house you'll never guess what : ) brass hose pressure nozzle. You know what they say, necessity is the mother of invention. Paul
  • Super Sportster
    replied
    Originally posted by frogpond View Post
    there was one that had seal on both ends SCE 1210PP on Amazon I wasn't sure if you want it
    that sealed up any thoughts on that? thanks for the information seal spring up got it. I have a NOS shaft coming from California my shaft has threads on gear end so unable to flip it around. Regards, Paul
    I don't think you would want a sealed bearing, the gear lube would never get to it. I haven't tried to flip the collar on a threaded pinion but it looks like the shaft is tapered at the threads and if you remove the pinion gear it could be done? I too was going to put the seal in spring down and the double seal lower one down and upper one up, but the experts said no they go spring up. I've not encountered any water in the lower unit doing it this way.
  • frogpond
    replied
    That explains why my needle bearings were so rusted up they had the seals in backwards and that's the way I would have installed the new ones as soon as I find a replacement I found several sources on internet for bearing just general search using SCE 1210 bearing number came up with results found a Timken and went with that there was one that had seal on both ends SCE 1210PP on Amazon I wasn't sure if you want it
  • Super Sportster
    replied
    I'm working on finding bearing and seal source and will post when obtained. my unit had two stacked seals literature that I have show only one perhaps someone can shed light on this? Regards, Paul
    Paul, Early units used one seal, later units used two seals. They must have been having a problem and the fix was two seals. When installed the seal spring side is toward the impeller side. Pressure from the pump is greater than gearbox side and keeps those seals watertight. If the seal area on the driveshaft is grooved it is removable, I've just flipped them over and reinstalled with red loctite or you can have new one made.
  • frogpond
    replied
    To all, so this is how I/you do it, get a piece of 3/8" all thread, buy 3 s.s. 3/8" nuts now thread two nuts on one end string a 1/2"drive socket with a 15/16" O.D. (outside diameter) this is about right the bearing is 1" O.D. your going to use socket utilizing the threads to push the bearing and seal upward make sense you'll see in a minute. the picture shows the setup by tighten the nut you pull the bearing and seal at the same time previously I've been soaking the bearing with Kroil available at Tacoma Screw Liquid Wrench works almost as good Acetone and automatic transmission fluid works better than both. I used some Oak to protect surface and the black bar is a 3/8" plate steel with 3/8" holes drilled through it put all this together as picture shows tighten to about real tight to fairly tight 40 ft lbs. smack the bottom end of the thread with brass punch. a nut threaded even to end as not to damage threads this is what worked for me. This method was given to me by "Super Sportster" I am only sharing the love any problems will be cheerfully addressed. I'm working on finding bearing and seal source and will post when obtained. my unit had two stacked seals literature that I have show only one perhaps someone can shed light on this? Regards, Paul
  • frogpond
    replied
    It took a little more soaking and pounding but she finally barked it it up.
  • frogpond
    replied
    Well as a matter of fact I did! : ) just before I went on vacation : )) I took a couple pictures and was going to post to help someone maybe in the same spot. Lets see what we can do that makes sense ; ) .
  • Super Sportster
    replied
    Thanks Dick I'll give it whirl when i get home from work Tues. now I know which way to pound on it :P
    Paul, did you ever get this out? Did you find a replacement bearing from the numbers I gave you?
  • Super Sportster
    replied
    Originally posted by John Nelson View Post
    The 85 didn't use a collar and the shaft was pretty soft. As you know I had cronic water in the 55. One of the times I tank tested it I had little bubbles coming out between the collar and the shaft 7 psi. It got traded off for a Vashon trawler title. I still think about it I blame it on the shift shaft seal. I changed it I didn't seem that good?????
    I never had my 85 lower apart as it was watertight. Never thought about it not having the collar, definitely wouldn't since the driveshaft was larger. I still have the 85 lower unit complete with the impossible to find impeller.
  • John Nelson
    replied
  • Super Sportster
    replied
    Paul, # on the bearing? SCE1210
    John, you know the collar on the driveshaft that the bearing and seal(s) ride is pressed on. You can make new. I've removed the ones that are not bad but have seal grooves and turned them upside down to get a new seal surface.
  • frogpond
    replied
    Dick I can almost read those numbers can you post that thanks, Paul
  • frogpond
    replied
    Mine was mangled and petrified. I had to grind thru the bearing with a dermal tool stopping before I hit aluminum, and peel it out with a chisel and needle nose pliers then have the drive shaft repaired also.
    Thanks for your input John, yeah thats about the shape mine is in, squirt some more Kanoil on it and give it another whirl I have a dremel tool yikes that sound like alot of work.
  • frogpond
    replied
